3D Model from Cosmos can't be deleted
  • 3D Model from Cosmos can't be deleted
    Hello everyone !
    Since the release of Vantage 2.0 I'm using it daily on my interior design project. It is super usefull and make our workflow really faster and simpler.
    I have an issue with a 3D model I downloaded from Cosmos which was deleted so it doesn't appear in the Rhino 3D model but is still here on the Vantage viewport.
    I tried to import the model again to delete it but it doesn't work : I can add new instances of the model and delete them but there's still few instances that can't be deleted.
    Any ideas on how to solve this problem ?
    Thanks all !
    I use the latests Rhino3D / Vray / Vantage releases.
    Thanks for reporting this. We will look into it. Do I understand correctly that you are using live link and you are not exporting a vrscene file? As a workaround maybe you can find the asset in the Vantage object list and delete it from there.
    Nikola Goranov
    Chaos Developer
      Hello !
      Yes I'm using the live link with Rhino. The thing is there is no object list while using the live link so I can't delete it from Vantage.
        Ah, yes, I forgot. It's removed on purpose to avoid conflicts between modifications made through Vantage and the host app (Rhino).
        Nikola Goranov
        Chaos Developer
          Originally posted by kevin_sourivong View Post
          Hello everyone !
          Thanks all !
          This sounds like a V-Ray for Rhino issue.
          Does the deleted object appear if you render with V-Ray for Rhino ?
          Greetings,
          Vladimir Nedev
            Hello,
            The object does not appear in a standard render with Vray for Rhino, only in Vantage.
            Any ideas on what could be the issue ?
              Hello,
              No idea, we would need the rhino scene file to debug it.
              Greetings,
              Vladimir Nedev
                Hello kevin_sourivong​!
                Can you please provide us more information for the steps to reproduce the issue or a short video showing it?
                We can not reproduce it on our side. During Vantage live link the scene is automatically updated if:
                • a Cosmos asset is deleted from the scene in Rhino
                • a Cosmos asset is deleted from the V-Ray Asset Editor
                • a Cosmos asset is deleted from the Cosmos browser window
                • a Cosmos asset is deleted from the selected Cosmos download directory's folders - Lock and Packages
                Downloading an already deleted or missing Cosmos asset is not updated in Vantage automatically - the asset is shown after restarting the live link (similar to the V-Ray Interactive rendering in Rhino).
                Could you please send us a test scene (packed project from V-Ray > Pack Project...) with the issue through our support portal (https://support.chaos.com/hc/en-us/requests/new) with the link from this forum topic in the message? This way we could be able to investigate the issue further on.​
                Thank you.
                Regards,
                Ivelina
                Ivelina Mincheva
                V-Ray for SketchUp | V-Ray for Rhino | QA
                www.chaos.com
                  Can a workaround be setting a scene state with the object off so that it doesn't show up in the renderings?
                    Hello Luma3d​!
                    In Rhino's right panel there is an option for the object's visibility. It can be found in Properties > V-Ray > Object Properties > Visible. When it is disabled, the object will not be rendered.
                    Kind regards,
                    Ivelina
                    Ivelina Mincheva
                    www.chaos.com
