Edge trimming doesn't work
  • Edge trimming doesn't work
    if I render in Max (bottom left image), I just need the texture to have the edges trimmed,
    If I render in Vantage it simply doesn't work, either using edge trimming texture, neither using edge trimming option inside chaos scatter object...
    What am I doing wrong?
Name:	MAX RENDER WITH CHAOS EDGE TRIMMING TEXTURE.jpg
ID:	1186824 Click image for larger version
Name:	VANTAGE RENDER.jpg
    Hi marcello_pagnan,
    You have to enable Opacity rendering from the top toolbar>Render settings and the edge trim should look the same as in Max.
    Alexander
    Alexander Atanasov
    Chaos
      I am so dumb!
      it's workin now
        We will improve this behavior in the future - when opening a scene to detect if there are materials with opacity or scatter's edge trimming and enable Opacity rendering.
        Alexander
        Alexander Atanasov
        Chaos
