"Always on Top" hides the HQ render progress when...
  • "Always on Top" hides the HQ render progress when...
    Hi!
    I found that when I have "Always on top" enabled, it hides the Render HQ progress, but it only happens when there is only 1 monitor. When I plug the monitor the laptop and I have 2 screens, it works fine.
    Is it me or is it for everybody?
    Thank you!
    (edited to add image)
Name:	Sin título-1.jpg
    HI, I tested what you describe and the render progress does not disappear. I disconnected one of my monitors, enabled the "always on top" and started a HQ render. Are these the correct steps?
    Vladimir Krastev | chaos.com
      Hi Vladimir!
      I realize I was wrong on how to replicate the issue. It is not about the number of monitors. It happens if "Always on top" (hereinafter AoT) is enabled before the first render of the session.
      Steps to replicate the issue:
      1) Close Vantage if already open.
      2) Open Vantage.
      3) Enable AoT.
      4) Hit HQ render.
      5) The progress dialog is missing.
      Once you disable AoT and render once, the dialog will show again and will always work for the rest of the session. With and without AoT.
      Sorry for the confusion, accidentally I replicated the issue while plugging and unplugging the monitor
      Thank you!
        Hi Galeon,
        I have logged in the issue in our system(LAV-1606) and we will let you know when there is some development.
        Alexander
        Alexander Atanasov
        V-Ray for Unreal & Chaos Vantage QA
        Chaos
          I have also just encountered this issue as well. Only when Always on Top is enabled.
          Matthew Valero, ASAI
            Hi guys,
            The fix for the Always on Top issue will be available in the next release.
            Alexander
            Alexander Atanasov
            Chaos
