chaos vantage crashes and exit
  • chaos vantage crashes and exit
    Hello,
    I am getting this error. I am also unable to start chaos vantage. As soon as I start chaos vantage, starting scene comes and it crashes without any error.
    When I do livelink from 3dsmax, it crashes as well.
    and I get this error in 3dsmax. I have allowed all chaos services in firewall as well. But still unable to keep it running.
    Hi jhjariwala,
    Can you send the Vantage debug_log file located in %AppData%\Chaos Group\Vantage?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Here is the file.
        I managed to export entire scene in VRScene and then it renders. But initial parsing time was long.
          It looks like the crashes are caused by a broken database in Chaos Cosmos. Try the steps for deleting the DB files here: https://docs.chaos.com/display/COSMO...Browserservice
          We expect to have a permanent fix for this issue soon.
          Nikola Goranov
          Chaos Developer
            Thanks! I will try with that.
              now works fine! Thanks a ton!
                Side question: according to the log file you have 3080 Ti + 3090 Ti and driver 537.42, but DLSS could not initialize. Is this indeed the driver you have? DLSS should work on such GPUs and driver 537+, so I'm puzzled...
                Nikola Goranov
                Chaos Developer
                  Yes, I installed latest drivers. But I am using Gameready drivers. Should I uninstall drivers using DDU and then reinstall it?
                    If you don't mind, try reinstalling the driver. If DLSS initializes correctly, it will be available in the denoiser list in Edit->Preferences->Render Defaults.
                    Nikola Goranov
                    Chaos Developer
                      Thanks! after reinstalling drivers using DDU, it works fine now. I see DLSS!
                        I still get this an error with livelink :
                          and DLSS support is gone again! Should I downgrade from 537 to 536 drivers?
                            I reinstalled nvidia drivers but DLSS is still not available
                            • #15
                              Sorry, I don't know what is causing this. You said that a clean driver install fixed it last time. In any case, driver 537.13 or newer is required for DLSS. 536 won't work.
                              Nikola Goranov
                              Chaos Developer
