SketchUp to Vantage Displacement Issue
  • SketchUp to Vantage Displacement Issue
    Am I missing something? I am using the displacement modifier but the result in Vantage is not working the same as in the engine within SketchUp. Seems to ignore Keep Continutity and the result is very jagged no matter what tesselation settings I use.
Name:	Screenshot 2023-12-13 092111.png
    Matthew Valero, ASAI
    It seems to be a known issue. It is happening to me as well. I got something that worked when I removed the negative number in the displacement.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      See this thread for an answer
      https://forums.chaos.com/forum/v-ray...nt#post1197539
        Hi ValeroStudio,
        We have release a new version 2.2.1 where the break at the edges should be fixed. Can you please update and check if it works for you?
        Alexander
        Alexander Atanasov
        V-Ray for Unreal & Chaos Vantage QA
        Chaos
          Fixed!!!! It's gorgeous! Excellent work Team Chaos!
