Displacement
  • Displacement
    My siding uses a displacement modifier, and it looks like it is melting. It looks great on CPU and GPU. How can I get it to look good in vantage? What is the trick?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hi Bobby,
    Can you provide a screenshot of the siding? i can only guess that the tessellation is not sufficient and the sharp edges are not extruded properly. You could try to subdivide the facade geometry to help the displacement.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      I have tried, but it didn't make a difference. I'll post something shortly.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        This is as good as I can get it. Again, looks very good in CPU and GPU.
Name:	Screenshot 2024-03-01 163339.png
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          It's just a guess (I don't have a Vantage sub any more to test) but does lowering the filter mult fix it?
            It's because your mesh still doesn't have enough subdivision per vertex opposed to per pixel (which is what you're seeing with CPU/GPU from Max). You need to increase your tessellation settings within Vantage - which you have plenty of room for given you're only consuming about 1/3 of what your card can handle.
              Okay, I'll give it a go. Thank you!
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
