vrayproxy not working with vraydisplacementmod
  • vrayproxy not working with vraydisplacementmod
    Hello,
    Is this supported? My tests are based on the below instructions for Vray and I can't get it to work
    https://forums.chaos.com/forum/v-ray...nt-in-material
    Thanks
    Hi rita_sobral,
    I my test the displacement works fine on proxy objects(I tried it on a cosmos tree asset): https://drive.google.com/uc?id=1V6hg...QfVMDdnSW8_HWH
    Can you please hare the scene you are testing with so we can investigate?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      I had 'Emulate 2d Displament' turned on in Vantage and that looks to be the issue. However, vray displacement worked normally otherwise, on non proxy objects and with 3d mapping set... So perhaps that setting is causing an issue only with proxies?
      THanks
