sunset animation - strange halos, flickers and flashes
  • sunset animation - strange halos, flickers and flashes
    hi,
    when rendering an animation with a sunset-sequence (animated vray sun + sky + clouds)
    there are always some frames that flash/flicker.
    AND there are some strange halos/Shadows around the clouds and (sometimes) the objects.
    Just at the time the Sun sets and the sky gets dark.
    before and after the sunset it renders fine.
    I have tried various settings, but nothing changes, even with ultra settings...
    Motionblur is turned Off in Max and Vantage
    Is there a workaround or a fix?
    usually i render this few frames twice: one with only the sky and one complete +alpha channel and fix it in post.
    but its far from perfect.
    https://youtu.be/Ugl4KR7FUNY
    3dsMax 2024, vray 6, Vantage 2.2.3, RTX 4090
    This Scene contains Forest Objects (background Trees) and Anima 4d people
    Rendersetttings: Video @ 1440p, ultra-settings, 600 samples, nvidia denoiser​, dynamic Textures Off, LC Sample limit 1024, LC retrace 2,5, LightsTree 4
    attached a frame with heavy ghosting and weird looking clouds
    Thanks, Dave
    We have this fix in the 2.3.0 changelog:
    - Fixed wrong cloud shading with sun slightly under the horizon
    I'm not sure if this is one of the issues you observed - it was causing the clouds to go white for a few frames while the sun dips below the horizon.
    But the blur is probably due to a denoiser issue or a live link synchronization issue. Is there improvement is you set a longer timeout in the live link settings dialog in Max, like 2 seconds instead of 0.1 ?
    Nikola Goranov
    Chaos Developer
      Hi and thanks for the quick reply!
      i rerendered the animation with the new vantage 2.3 update and that fixes the clouds - flashing - problem
      and the blur/halo problem was fixed by using the legacy denoising mode
      i have not tried the live link settings you suggested, but good to know that there ist someting to play around
      thank you very much and have a nice day
      Dave
        Oh...need to update. I ran into the same issue rendering out solar studies yesterday.
