ACEScg scene not outputting true AP1 colour
  • ACEScg scene not outputting true AP1 colour
    is it true that Vantage will render ACEScg vrayscenes from VRay but the output (even "raw" exr) will be limited to BT.709 ???
    it would be contrary to what was stated here:
    https://forums.chaos.com/forum/chaos...05#post1212505
    but I'm trying and so far failing in getting ACEScg exr from Vantage. Everything I get is BT.709.
    Colour management in 3dsMax2024 set to legacy gamma, all textures correctly tagged (colour space) via VRayBitmap.
    I have 2.5.1 at the moment (not able to update but there is nothing in the full changelog)
    scenes and outputs attached.
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
    The actual .vrscene is missing, could you send it? Max files would also be helpful. It's hard to say what's going on otherwise.
    The raw exr output is not limited to BT.709, it will be in the rendering color space of the scene - linear BT.709/sRGB or ACEScg/AP1. The output in the viewport however is limited to sRGB, unless you have an HDR monitor.
    Vantage 2.5.2 does contain an important fix for the ACEScg support actually, but in this case with the legacy gamma color management in Max I'm not sure it's relevant.
    Radoslav Platikanov | Chaos R&D
      thank you for looking into this.
      Marcin Piotrowski
      youtube
      CGI OCIO config 04
        Thanks for the files. I'm getting exactly the same .exr results as V-Ray with Vantage 2.5.1.
        The only thing I can see is that acescg.vantage points to the sRGB scene actually, not the ACEScg one. You can verify the color space of the current scene in File -> Scene Stats -> Scene units.
          my mistake - apologies for wasting your time. everything works as expected.
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
            No problem, good to know it's working.
              for what it's worth - I'm attaching a lut that will help visualise aces srgb display transform in Vantage:
              (not perfect - the error comes from Highlight burn behaving differently in acescg scenes)
              Marcin Piotrowski
              youtube
              CGI OCIO config 04
