visible cross shadow ground plane at origin
  • visible cross shadow ground plane at origin
    I have an issue with my ground plane. We render a lot of machinery in a white environment. We use a simple white plane for the shadows. I often get a cross in my shadow. This is right at the origin of my scene.
    Do you have any explanation for this problem?​
Name:	Cross ground plane.png
    We've seen this issue before, yes (LAV-50). Moving the object a bit away from (0,0,0) should help.
    Nikola Goranov
    Chaos Developer
      Thank you, this made the problem considerably less. A light spot is still visible at the 0,0,0 point, though.
Name:	Spot ground plane.png
        Do you have ambient occlusion enabled?
        Nikola Goranov
        Chaos Developer
          If i turn of AO in the Vantage settings the problem is solved. Thank you!
