Displacement jittering
  • Displacement jittering
    (Video example in the link and mostly visible on the metal jaw) As I tested, vantage has an issue with displacement on deforming objects, no matter its settings: disabling dynamic textures and some other things (only not checked if it is set to none). I am unsure if it is a problem with displacement normals(the original object is just regular subdiv), and why some shadows disappear once the object starts to deform. Also, I think that tesselation resolution is based on units is an issue cause high preset dont provide enough detail in cm, but does in meters. Pertriangle tesselation does not always work perfectly and would be nice to add some more settings to it.
    Click image for larger version  Name:	ewrerwerw4w453534543_2 копия.jpg Views:	0 Size:	580.9 KB ID:	1225609
    Maybe Vantage always tesselate any face based on it area, cache it, and forget to update while deforming?
    I've tested the object with displacement modifier with no tesselation and it's still jitter when deform, but the issue disappears when I replace vray displacement with regular geometry displace modifier. Maybe there's some setting to prevent it, but didn't find
