UVW Channels
  • UVW Channels
    Hi all,
    Is this supported, it suggests it is in the help docs?
    See attached screen grab, the dots are on map channel 4 and should only come on for a few objects in the scene and then at a much small scale?
    Material misbehaving.
    Chaos docs...
    Mega thanks in advance as always,
    Jason
    AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.4894, 3dsmax 2025.3, Vray 62006, Vantage 2.5.2​
    See attached screen grab, the dots are on map channel 4 and should only come on for a few objects in the scene and then at a much small scale?​
    So some of the objects don't have channel 4 at all ?
    It's possible that the V-Ray and Vantage behavior is different in such cases.
    Vantage will certainly fall back to the default uv channel (1 in 3dsMax).
    Not sure what V-Ray would do.
    Can you send us the scene, or just the affected objects and materials for investigation ?
    Greetings,
    Vladimir Nedev
      Also, are you on Vantage 2.7.0 ?
      We have the following bug fix there : "Fixed random colored pixels when a mesh has three or more UV channels/sets with some unused"
      Greetings,
      Vladimir Nedev
        Yes, Vantage 2.7.0, it's showing channel 4 which is in the opacity map for the perforations, this is used in 3dsmax vray material and is on channel 4 and so should be off when there aren't any UVW channel 4 maps
Name:	UVW without channel 4.jpg
        Object should not have preforations as no UVW channel 4 present
Name:	UVW with channel 4.jpg
        Object with UVW channel 4 present and showing perforations correctly.
        One thing to note is that the same material is applied to both obejcts but with differing UVW channels.
        I can resolve this by creating an additional material but that it is unnecessary in 3dsmax/Vray itself.
        Thanks again,
        Jason
          Ok, I need the scene or just the affected objects to investigate exactly what's wrong.
          Greetings,
          Vladimir Nedev
            My guess is that Vantage is falling back to the default channel, since channel 4 is completely missing.
            What should happen in such cases is a bit complicated, since we need to support other DCCs and
            also cross applying Maya/3dsMax materials to 3dsMax/Maya objects where the default channel has
            a different number (1 in 3dsMax, 0 in Maya).
            Greetings,
            Vladimir Nedev
              I can break out the objects very easily and send them across for closer inspection, where is best to send it?
              Jason
                Jason
                The e-mail in my signature. Thanks.
                Greetings,
                Vladimir Nedev
