command line (CMD) to take screenShots
  • command line (CMD) to take screenShots
    when I need to take a series of screenshot(differient camera position ), is boring to click UI. so I want to write scripts to run.
    Hi max_romju,
    Will a 'command line' like functionality work for you?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      yeah,thanks for reply . this Will be highly efficient.
        Great. We have that logged as a request but cannot give ETA for it. We will inform you when there is development on the matter.
        Alexander Atanasov
        Chaos
          dear Alexander.Atanasov, is there any progress?
            Hi max_romju
            No, nothing in development yet, we will try to do something for it in the next or the next next release.
            Alexander
            Alexander Atanasov
            Chaos
              We've added command line rendering in 1.5.0 - see "vantage_console.exe --help".
              Nikola Goranov
              Chaos Developer
                Superb and it works like a charm.
                Future whislist for the command line for us would be:
                - Render in an scene which is already open (it now already can detect if an instance is already running).
                - Adjust / Add / Change materials of objects
                - Move, rotate, scale objects
                - Adjust the camera (position (x,y,z,), rotation and camera settings)
                - Merge different scenes
                - Export 360 renders
                and so on.
                  What would be the purpose of this? Is it that you want to run a bunch of jobs and simply avoid the overhead of restarting Vantage for each command? In this case, we are working on batching renders from the UI.
                  You can do this now by saving your cameras to a vantage file and then using -camera "name" on the console.
                  Changing materials and moving objects is closer to full scripting. I'm not sure how appropriate it is for a single command line. But I have an idea for a possible "middle ground" solution...
                  Nikola Goranov
                  Chaos Developer
