Is it possible to use MAXscript to get or set vantage parameters during real-time link
  • Is it possible to use MAXscript to get or set vantage parameters during real-time link
    For example, data exchange through vraydr?
    Hi q976431,
    Can you explain more what are you trying to achieve, what type of data and what parameters you wish to set/modify?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Originally posted by Alexander.Atanasov View Post
      Hi q976431,
      Alexander
      At present, I haven't figured out what I need to do. If I can, I hope I can control most parameters of vantage through MAXscript
      Because I know the benefits of this function. I will be able to control vantage using 3dsmax callback or other MAXscript commands to make my own tools to optimize the workflow
      Will you consider using MAXscript to get the parameter value and status of vantage in the future
      When linking in real time
        Hi q976431,
        Alexander
        For example, the current environment does not support real-time Association of vraydome map rotation to vantage
        If I can read and set the environment rotation parameters of vantage
        I will be able to create callback in 3DMAX. When I rotate the rotation angle of HDR in 3DMAX, I will automatically rotate the environment rotation parameters of vantage through callback. In this way, I can complete similar functions through development tools before you support this function
          We do not support general scripting at this point. It is theoretically possible, but it is not on our short-term roadmap. We're taking note of your request, of course.
          Nikola Goranov
          Chaos Developer
            The environment updates while in live link are already fixed in our internal builds and being tested. The fix will very likely be part of the next release.
            Greetings,
            Vladimir Nedev
              Greetings,
              Vladimir Nedev
              OK, this is just my example
              Because if you implement the link between MAXscript and vantage
              I can design some tools for my workflow
              I wonder if this idea is possible?
