Support with VrayClipper (with mesgmode)
  • Support with VrayClipper (with mesgmode)
    Hello,
    For complex scenes with architectural buildings the Boolean Modifier isnt the solution. Vray Clipper with the meshmode on is perfect to open up a building without destroying the geometry.
    Is it posible to make it work with Vantage?
    Thanks for the Multitexture and Glossines refraction!!
    kind regards,
    Richard.
    Hi Richard,
    We have V-Ray clipper(LAV-623) logged in our system but it is not as high a priority at the moment. We will let you know when there is some development on the matter.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      HI, Is there any news on Vray Clipper support? the slice modifier is not a valid solution because for a building with many objects the solution is not to collapse everything into a single mesh.
      Thank you​
        another vote for clipper (same thing, architecture)
          Yet another vote for clipper! It absolutely required! (in architecture)
            another vote for clipper !
            thank you for your work!
            Filippo
