This would be great because I thought I was going crazy until I realized they weren't supported. I am also only using normal maps before any of these.
This is quite essential if creating blended materials and using normal maps... Displacement works fine with these maps but need the normal map to give it texture.
Thanks
EDIT: So it does work with normal maps just not bump maps - it was a bump map that was causing an issue so acutally I can work around this by disabling the bump on the node before
Thanks
