Using a Ramp for a Environment Fog Gizmo colour
  • Using a Ramp for a Environment Fog Gizmo colour
    https://docs.chaos.com/display/VMAYA...nmentFog-color
    "For the last 2 images, the fog Color has been mapped with a texture. World XYZ mapping type was used for the textures."
    How exactly is this achieved? I've tried plugging in a ramp to the emission attribute for the Environment fog but it only sees the first colour, and doesn't use the UVs of my gizmo object. I've tried using a projection node plugged into the emission colour too, but this doesn't work either.
    I'm attempting to use Env' fog to create a spaceship thruster, and need to map its colour via a ramp.
    This is how I set it in Max, using just emission and transparency...don't know if that helps or not but it should translate.
    Just in case it's not noticeable, I set the mapping to objecxtxyz rather than world, which works fine for noise but not a gradient in this instance
      Thank you for your response. Unfortunately, in Maya there isn't the option to set the mapping in the same way on a ramp node. A 2D UV-Based node or 3D projection has to be plugged in to the texture.
      Maya scene example here: https://we.tl/t-UlNWkDznfm
        Hi sebbiej,
        Thank you for raising this! There is a mistake in the documentation page and I'll correct it.
        You can use the projection node set as a Cylindrical and it should work as shown in the example. I'm attaching a simple setup you can download and check.
        Here's a link to the folder with the scene.
        Cheers,
        Kristin
        Kristin Ivanova
        Technical Writer
        www.chaos.com
          Brilliant, thank you very much Kristin! I'll check that out today.
            I'm guessing this setup doesn't work with VRay GPU?
              Hey sebbiej,
              It won't work with V-Ray GPU as setting VRayEnvironmentFog into a container is not supported yet.
              Cheers,
              Kristin
              Kristin Ivanova
              Technical Writer
              www.chaos.com
