trying to figure out which license type is used when. See attached image.
This is what the license server shows with two computers running 3ds Max and Vray Next. Two "Next" available but not in use and two render nodes in use. This is from when both computers renders separate scenes. Shouldn't the "full NEXTlicenses" be in use? I thought the render nodes only kicked in when using machines only used as renderslaves.
Also tried to render using DR with my workstation and a renderslave. When doing so the other workstation that have Next installed still function to work with but can't render. Couldn't obtain license (-98 )
Confused.
Confused.
