Vray Trial is rendering blank
  • Vray Trial is rendering blank
    I just triad Vray trial, and it's rendering blank black. I have Vray lights, tried some samples from the website, and used Vray in the past, so I am not a completely new user. There are some errors here (attching), plus it's says not in use when I check online.
    Please help,
    Already tried install and uninstall; turned off windows protection while installing; please help; otherwise starting to uninstall forever. Thanks for reading!!
    Do you have the latest license manager?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Yes! it's 6.2.
        Hello, use the link in my signature to submit a ticket. For Request type Chose Product usage questions or issues. The relevant support team will assist you further.
        Kostadin Botev
        Contact Support
        Chaos
          This error is probably caused by missing the Microsoft Visual C++ Redistributable. It's usually installed along V-Ray, but sometimes it needs to be installed manually. A setup file is included in the V-Ray files: "C:\Program Files\Chaos\V-Ray\3ds Max 2025\utils\vc_redist.x64.exe". Install it and see if the issue persists.
