Vray next update 1 Can’t connect to license server
  • Vray next update 1 Can’t connect to license server
    I installed vray next update,1 for 3ds Max 2019. Previously using vray next , Max 2019 with no troubles.
    Now, after install I can’t connect to online license server. I think I need, per vray docs, a second set of user name and pword, different from what I use to log in to my chaos account. I do not seem to have these and cannot find how to,retrieve them.
    alos updated to most current (5.x I think) license server. Not using dongle.
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
    You don't need different credentials, I don't think we have something like that in the docs. Do you see your license listed when you navigate to http://localhost:30304 on the computer with the license server installed?
    You can also check your license settings - https://docs.chaosgroup.com/display/...cense+Settings
    Ivan Slavchev
    SysOps
    Chaos Group
      No I do not see the license listed. I get a cannot load page error message. I have sent a screen grab of that to you.
      There is a section in the help docs that says you cannot use your product user name and password. It includes a graphic:
      https://docs.chaosgroup.com/display/...+V-Ray+License
      mark f.
        uninstalled the license server, deleted folder per instructions from support, re-installed, used same credentials as my vray purchaes/account (despite the docs saying that will not work) and now have it working. Thank you.
        mark f.
