Could not obtain a license (-98): … but there is a license available!
  • Could not obtain a license (-98): … but there is a license available!
    Hi there,
    I am testing VRay for Modo and a headless Windows GPU server. Now I want to test distributed rendering, but I am always running into an error:
    error: Could not obtain a license (-9: There are no available licenses of this type on the ChaosGroup License Server.
    But there is an render node license. I do not understand it! Why is the render slave not able to find it? What is the problem?!?
Name:	Screenshot 2018-12-20 00.20.26.png
    I just figured out that the distributed rendering will work when I deactivate the local rendering.
    Is this a bug?
Name:	Screenshot 2018-12-20 00.42.57.png
      It's not a bug. A Workstation license package contains 1 Interface license that gets engaged when you use V-Ray's interface and 1 Render node license that gets engaged while you render - https://www.chaosgroup.com/support/f...in-the-license
      If the render node license is engaged by the local machine there won't be a free license for the additional render node.
      Ivan Slavchev
      SysOps
      Chaos Group
        Ah, okay. In this case I can not use V-Ray with the local machine and an additional network attached machine. Hmm …
        I also tested VRscans and I have a watermark in the materials, wehen I render with distributed rendering. Why is this? I have a test license for VRscans.
        And when I render via DR on my GPU server V-Ray is not using only one of the two GPU’s in that server and not CPU. Is this a bug or is this a limitation too?
        These limitations are only good to prevent little one man companies to purchase V-Ray. On larger companies these limitations has no effect.
          Yes, you can render on the workstation or on the render node. You'd need an additional render node license for the second machine.
          I also tested VRscans and I have a watermark in the materials, when I render with distributed rendering. Why is this? I have a test license for VRscans.
          You can check the license settings and restart the render slave. If you cn=ontinue having issues - message us at support@chaosgroup.com
          Make sure both GPUs are selected for rendering - https://docs.chaosgroup.com/display/...wareandDrivers
          Task Manager is not very good in monitoring GPU usage - you can use GPU-Z or similar tool
          Ivan Slavchev
          SysOps
          Chaos Group
            Thank You for Your answers.
            They are selected.
            I am using https://camwebapp.com
            And I can see it on the GPU’s itself, only one of them is blowing like a blower. The other is silent and the fans are standing still.
              Best to write us at support@chaosgroup.com in that case and we'll look into it.
              Ivan Slavchev
              SysOps
              Chaos Group
