Hi there,
I am currently having a problem with one of the slave machines I use for distributed rendering (V-ray 3.6 for 3DS Max 2019). I have 3 other machines as slaves which work fine (although a couple do drop out mid-render now and again).
The message I get on the host machine is:
Server 192.168.2.xx:20204: Could not obtain a license (-2): Internal error: Please contact ChaosGroup support.
Server 192.168.2.xx:20204 excluded from render
Warning: Render host xxxxx (Server 192.168.2.xx:20204) is not responding
I have made sure the firewall on the slave machine is allowing the following across Domain, Private and Public:
3DS Max
Chaos Group License Server
Port 20204-20211
I saw something on another post in the forum (for Maya but same principle I assume) which mentioned about using the CMD prompt and typing in telnet then IP of slave then 20207
I tried this with the 20204 and the text in the CMD window just disappeared when I pressed enter. With 20207 (not sure if applicable for my problem) the following message came up in the CMD window:
Could not open connection to the host, on port 20207: Connect failed
I would be grateful if you would be able to get back to me today as I need to run some animations over the Christmas Break.
Many thanks in advance
Graham
3DS Max
Port 20204-20211
Graham
