VRLSERVICE user.log size
  • VRLSERVICE user.log size
    this file grows to enormous size. Set from 'Verbose' to 'Errors only' - Hope that helps. However, it would be nice if this service limited itself to a max log file size. Preferable user controllable. Thx!
    What's the license server version you use? Also - is there a particular problem reported regularly in the logs that cause the file size to be this big?
    Ivan Slavchev
    SysOps
    Chaos Group
      I'm getting 25-30mb log files everyday!!!
      most of it is:
      {"component":"dongle_server","message":"Reloadi ng dongle licenses done","severity":"debug","time":"2019-05-24T22:17:09.6088299+01:00"}
      {"clientIP":"192.168.1.xxxxxx","component":"app","ctx.sessionId":"9f51b0e1b ccafacaaaf12766b4931b4b","message":"/getlic01 request received","path":"/getlic01/432A3EF1D5084C6E03CCA0D0913251062207AFB86FFEC4277F F1A4CEBF544D4DEA7B9CAD818C440F4A1A8035915A9772EA7B 9CAD818C440F4A1A8035915A9772EA7B9CAD818C440F4A1A80 35915A9772EA7B9CAD818C440F4A1A8035915A9772EA7B9CAD 818C440F4A1A8035915A9772EA7B9CAD818C440F4A1A803591 5A9772B23437789F51B0E1BCCAFACAAAF12766B4931B4B","s everity":"debug","time":"2019-05-24T22:17:09.6680535+01:00"}
      {"component":"dongle_manager","message":"Dongle subsystem handling license request","severity":"debug","time":"2019-05-24T22:17:09.6680535+01:00"}
      is this normal? License server is 5.2.2 (green light online, green light dongle)
      I do get a red error saying: (which I dismiss)
      DONGLE LICENSES HAVE EXPIRED
      V-Ray for 3ds Max 2.0 has expired on Aug 24 2014, V-Ray RT GPU has expired on Aug 24 2014
      Simon
      I need a new signature
      Max2017.1 | Vray 3.70.01| win11
      ASUS Z790PLUS | i9 13900K | 64Gb RAM | Geforce GTX4070Ti
        20-30mb/day is normal, older logs are automatically deleted (7 days are kept). ""severity":"debug"," indicates "Verbose" severity set, but maybe the message is from before you set the level to "errors only".
        You can get big logs in case you have several V-Ray spawners (especially older versions of V-Ray for Maya or V-Ray Standalone) running on the same machine at the same time (unless they are adjusted to use different ports).
        Ivan Slavchev
        SysOps
        Chaos Group
