Could not obtain a Simulation License! Error code: 10061.
  • Could not obtain a Simulation License! Error code: 10061.
    I sent a simulation off to BB and according to the License Server, there's one Simulation Node that's actively engaged. When I try to run a second sim from my workstation on a different scene, I get the error message. I was under the impression that you could run sims on BOTH a BB node and Workstation simultaneously. Is that not true, or is that because of its an EDU license?
    Thank You.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    You can't use a V-Ray Commercial build with Phoenix EDU build, or vice versa. Additionally - Phoenix licensing is like V-Ray's meaning that if the Simulation node license is engaged on another machine it won't be available for the local one and you'd need a second sim node license.
    Ivan Slavchev
    SysOps
    Chaos Group
      So my V-Ray Commercial license won't render my Phoenix EDU simulations?!? That's odd since IPR seems to work just fine.
      David Anderson
      Software:
      Windows 10 Pro
      Hardware:
      Puget Systems
      TRX40 EATX
      128GB RAM
        Phoenix licence is required when simulating. When you render you should have Phoenix installation present, but a licence will not be engaged.
        Ivan Slavchev
        SysOps
        Chaos Group
