No licenses available
  • No licenses available
    My main computer died, so I've migrated things over to my 8 year old laptop until I get things sorted out. Can't seem to get VRay working though. Any tips?
    - Geoff
    Here's a screenshot.
    Click image for larger version  Name:	LicenseError.JPG Views:	0 Size:	40.9 KB ID:	1106188
    - Geoff
      In order to work with V-Ray, you will need to activate your license in the V-Ray license server web interface "127.0.0.1:30304"
      Make sure that you installed V-Ray and V-Ray Online license server 5.5.2 (if you did not already install it):
      https://download.chaosgroup.com/?platform=47&product=48
      then please open in your web browser "127.0.0.1:30304" and see if you are able to Enable your Online licensing
      with your username or your e-mail and press "F5" on your keyboard in order to refresh the web page.
      If you are able to see your V-Ray license there, please start your 3D application and work with V-Ray.
      Note: We can see that you installed V-Ray 5 for 3ds Max, in order to work with this build, make sure that you have the latest V-Ray 5 for 3ds Max license,
      otherwise, you will need to downgrade and download and install the corresponding build according to your license you have.
      If any issue appears, please send us a screenshot of the issue and the web page "127.0.0.1:30304".
      Thank you.
      Stefan Isakov
      Technical Support Team Lead
      Contact Support
      Chaos
        Hmm...
        • Yep, the latest version of the server software is installed.
        • Nope, I can't enable the Online Licensing.
        • Yep, I'm logged in and nothing changes.
        • Downgraded to NEXT and got an error message when I started Max (attached).
        I do still have an old dongle that I can pop in, if that might help. Though your link to the WIBU key software needs to be updated.
        - Geoff
          Oh that's interesting. Even though I'm logged in, the license server page does not show my user name, only my machine name.
          - Geoff
            Could you please do the following in order to clean and re-install the V-Ray Online license server :
            1. Please close the Services window in your OS(if it is opened) and uninstall the V-Ray Online license server from your Start menu>Control Panel> Add remove programs
            2. Make sure to delete the folder C:\Program Files\Chaos Group\VRLService
            3. Go to the folder "C:\Program Files\Common Files\ChaosGroup" and delete all files and folders except "vrlclient.xml", which is needed.
            Please download and install the V-Ray Online license server 5.5.2 from our web site:
            After the installation is completed, please check if the V-Ray Online license server status page "127.0.0.1:30304" is available and you are able to click "Online licensing" >Sign In and enter your e-mail/username.
            Note: We can see in our database that your license is V-Ray 5 for 3ds Max, which means that you can install V-Ray 5 for 3ds Max build and work with it.
            If any issue/error appears, please send us a screenshot of it and another screenshot of the web page "127.0.0.1:30304".
            Thank you.
            Stefan Isakov
            Contact Support
            Chaos
              Awesome! It's working! Thank you!
              - Geoff
