Could not obtain a license
  • Could not obtain a license
    Windows wanted to install some OS updates. Now I seem to have lost my V-Ray license in the process. What now?
Name:	Screenshot 2025-04-09 210425 V-Ray.png
    For some reason one license is missing. I bought two render nodes, but I only see one. Is there anything I should do to fix this,
Name:	Capture V-Ray license. 2JPG.jpg
      I see both render node licenses, but I still keep getting the "Could not obtain a license" -error.
Name:	Screenshot 2025-04-09 213842 Render node.png
        To assist you further, we’ll need more details. Please use this link https://support.chaos.com/hc/en-us/requests/new to submit a support ticket. For the Request Type, select Licensing Assistance – Installation and Configuration.​
        That will help us check your account information and exclude possible scenarios.
        Regards
          Thanks,
          I did send an email to Chaos support in the evening. I'm waiting an answer for that. I don't want to create duplicate tickets.
            For some reason, I see two available licenses same time as VRay refuses to render, because there's no licenses. This screenshot is from the workstation I'm trying to render. It sees two licenses, but cannot use any.
            Click image for larger version  Name:	Screenshot 2025-04-09 213842 Render node 2.png Views:	0 Size:	29.1 KB ID:	1230514
              Originally posted by bano_banov View Post
              Regards
              I followed Your link and saw my request Request being solved. It's not solved.
              What do I need to do to get the support?
                A little development. Along with Windows update F-Secure was updated as well. First thing to do was disable F-Secure VPN, when I got the licensing Chaos Licensing problems. It didn't help that time. After a reboot it was automatically switched back on. So I turned it manually off gain and now it is rendering. Which Chaos software component I need to bypass in VPN.
                Earlier, before the latest F-Secure update, I didn't need to do anything to VPN settings. VRay licensing worked fine with the default settings.
Name:	Screenshot 2025-04-10 203229 VPN Bypass.png
