SketchUp 2018: Failed to checkout V-Ray GUI license
  • SketchUp 2018: Failed to checkout V-Ray GUI license
    Hello V-Ray Technical Support staff,
    My name is Valin and I’ve just installed V-Ray 3.6 for Sketchup – trial version – to consider it for purchase. When I try to run V-Ray from SketchUp I get the error: “Failed to checkout V-Ray GUI license”.
    I saw on the V-Ray Forum the advice to delete the cgauth.dll file from the Sketchup 2018 folder if I found one in there. I looked and did not find this file in the folder.
    The name of the V-Ray installation application I used is: vray_trial_36001_sketchup_win. I installed SketchUp 2018 and V-Ray to my D: drive so my C: drive mainly handles my OS – Windows 10 64 bit. My key computer hardware is an Intel Core i7 6400 CPU and Nvidia GeForce GTX 1080 FE graphics card.
    Thank you in advance for your help! I've sent this same message to the V-Ray tech support email address.
    Valin
    Win 10 64 bit OS, Intel Core i7-6700 CPU @ 3.4GHz, 16 GB RAM, GeForce GTX 1080 GPU
    I found this link in the Forum to the latest license server ( https://download.chaosgroup.com/license-server ) and downloaded re-installed the license server and now V-Ray is working for me. Looking forward to exploring its capabilities!
      I keep getting this error after reboots of my PC on first SketchUp start. When I run the license installer again it goes away until the next reboot.
        You can check the startup type of the license server service -> Run-> services.msc->VRLService. By default should be set to "Automatic (Delayed Start)" - you can right-click it and chage the startup type if another one is set.
        Also - if you hav an ativirus - check the logs if it doesn't delete the license server's service - you can add an explicit exception for it.
        Ivan Slavchev
        SysOps
        Chaos Group
