Upgraded to Vray Next - Slaves Cannot Find Licenses
  • Upgraded to Vray Next - Slaves Cannot Find Licenses
    Everything was working fine with version 3.6. I've attached the License Manager page. I have Max 2019, Vray Next with a client and server license and purchased and additional license for another render slave.
    So my setup is 1 workstation (client) and 2 renderslaves (servers).
    I have tried all of the typical workarounds and have not been able to resolve the problem.
    Daniel Black
    Archtagon LLC
    www.archtagon.com
    I just saw an email that the license server has to be upgraded. I assumed that was done with the Vray Next install. I will do that when back in the office and see if that solves the problem.
    Daniel Black
    Archtagon LLC
    www.archtagon.com
      Yes, you should update the license server. The V-Ray Next installer is now updated to include the latest version, I believe.
        i still cannot obtain a license
        Daniel Black
        Archtagon LLC
        www.archtagon.com
          Will bring somene from our licencing support to assist here.
            Hi, we'll write you via the ticketing system, as usually - license info is best not to be shared here.
            Ivan Slavchev
            SysOps
            Chaos Group
              Thank you, the problem persists and its really holding me up. I even upgraded my renderslaves to Windows 10 like my server. But that didn't do any good. Now I can't even see my machines on the network
              Daniel Black
              Archtagon LLC
              www.archtagon.com
                Heres a screenshot of the vray message
                Daniel Black
                Archtagon LLC
                www.archtagon.com
                  Having the same exact problem. I also bought the workstation and additional render node. Shouldn't the numbers say INTERFACE: 1 and RENDER : 2? Mine also says 1 for both and am now getting the same 1002 error.
                  On my Vray 3.6 I bought 1 workstation and 2 other render nodes. The License server says INTERFACE 1: and RENDER : 3.
                    Mine is definitely a licensing problem. I have gotten 1 render node to work while the 2nd node still comes up as unlicensed. So my server and 1 node participate in the DR and the 2nd does not. It also crashes Max when render is done trying to use both nodes.
                    Daniel Black
                    Archtagon LLC
                    www.archtagon.com
                      Please - everyone having problems as the one above - message us at support@chaosgroup.com.
                      Ivan Slavchev
                      SysOps
                      Chaos Group
