Pdplayer 1.0.5.21 released
  • Pdplayer 1.0.5.21 released
    Pdplayer now offers numerous enhancements and new features
    Pdplayer, the professional image sequence player and viewer for the 3D, CG and VFX industry, distributed by Chaos Group now comes with a full list of improvements.
    Now this advanced image sequence player offers you:
    1. Improved cross platform integration with Nuke (support for Nuke 6.2)
    2. Support for AJA for Windows
    3. MAC OS X and Linux trial versions
    4. A number of improvements and fixes
    The sequence player is famous for its flexibility, exceptional ease of use and lightweight, despite the rich list of features. It supports most industry standard file formats including EXR, HDR, DPX, CIN, R3D, TGA, SGI, IFF, PIC and VRIMG. Multiple layers can be color-corrected and composed together in real time.
    Pdplayer is a great addition to numerous studios’ pipelines. Here is what Blur team shares on their experience with Pdplayer:
    “It's insanely FAST to load image sequences, has a logical layer system, useful hotkeys/functionality for managing those layers and sequences, handy color space and image adjustment controls, it can apply alpha masks for quick dirty comps, and has fun paintbrush tools for notations per frame. Pdplayer is all around awesome product.”
    Here is the official change log:
    1.0.5.21:
    • Nuke flipbook integration is now cross-platform and supports Nuke 6.2 (#382)
    1.0.5.20:
    • Fix #354 (Frame buffer layers on Linux and Mac OS X)
    • Fix #394 (Relative .pdpcmd filenames don't work)
    1.0.5.19:
    • Added support for AJA Kona on Windows via DirectShow
    AJA DirectShow drivers are available from http://www.aja.com/products/oem/directshow.php
    Note that these drivers only support 32 bit applications at the moment
    • Fix #241 (Scale is not exported properly to Nuke)
    1.0.5.18:
    • Added WAV export (#376)
    • Fix #379 ("Rescan for new frames" doesn't work after switching a version)
    • Fix #383 (Versioned movies in the same directory don't work)
    • Fix #392 (Add a command line option for PCM audio in MOV export)
    1.0.5.17:
    • Fix #372 (DPX images with a certain size don't work over the network with an XP64 client)
    • Fix #384 (Save Layer as... doesn't properly filter AVI codecs by the layer resolution (always uses mask))
    • Fix #386 (No command-line option to set the layer audio volume)
    • Fix #387 (No command-line option to set the global audio volume)
    • Fix #388 (The layer volume is not exported to .pdpcmd)
    • Fix #390 ("Position after Next Layer" should support multiple selection)
    1.0.5.16:
    • Add --crop={left_half,right_half,top_half,bottom_half} (#385)
    • Fix #389 (Display peak audio volume in the layer tooltip)
    • Update software license server to fix an issue with single machine taking more than one license
    1.0.5.15:
    • Fix #357 (No command-line option to set the alpha source)
    • Fix #365 (Set Work Area to Selection doesn't work when multiple layers are selected)
    • Fix #366 (Duplicate should add an apostrophe to the layer name)
    • Fix #367 (Duplicate should work when multiple layers are selected)
    • Add --layer_resize_to_mask (#36
    • Add --layer_align_to_mask (#369)
    1.0.5.14:
    Fix #378 ("Add Other Stereo View" doesn't seem to work properly with Quicktime movies)
    1.0.5.13:
    • Add high quality hint to DV Quicktime tracks on export
    • Always decode Quicktime at high quality on playback
