Smoke sim like the one in the docs??
  • Smoke sim like the one in the docs??
    Is it possible to get the settings to get a smoke sim similar to the example in the docs for vorticity?
    https://docs.chaosgroup.com/download...2808000&api=v2
    Thanks.
    Yes, just search the forum, I already shared this one recently in another thread
    Cheers!
      Thank you Svetlin,
      I found the thread with the scene file
      However the simulation comes out quite different from your example in the docs.
      I am trying to get the look like the classic vorticity example which looks more like underwater paint, so I set the Vorticity parameter to Classic=0 but the result has loss in detail and overall shape is not like your example.
      Please see the attached image.
      I tried increasing the resolution too but that makes no difference.
      Any clues?
        Hey,
        Indeed, the scene from the docs is on a higher resolution - you can visually see the difference in voxels looking at the images and the GPU preview. If I remember correctly, you should increase the resolution 4-5 times to like 11 or 22 million voxels up from 1'568'000.
        You could also try adding some Noise to the Source to help break up the mushroom.
        Cheers!
