Hey, sorry for the very long delay - got a wetmap issue I wanted to fix and so it took longer than I expected:
- Make sure to grab a latest nightly build or the issue will affect your simulation!
[test] daredevil max2016.zip
Hope this helps as a starting point - you can adjust the viscosity and surface tension from this point. I am using a body force to attract the liquid to the geometry to that it sticks better and you can regulate the distance of the body force too.
