Particles [Liquid] of [Phoenix FD Liquid 001] shading
  • Particles [Liquid] of [Phoenix FD Liquid 001] shading
    is it possible to shade :
    Particles [Liquid] of [Phoenix FD Liquid 002] using the particle shader, similar to how fog/splash/foam works?
    i tried hooking it up , but nothing renders.
    I know you can use another fire/smoke simulator to load in vorticity from flip "special" output and shade that way...but i was thinking i could just use the "liquid particles" with velocity data to shade aswell
    cheers
    Harv
    Hey,
    Yes - this should be working. Can you show us your settings or attach a scene so we can check what is going on?
    Thanks!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      You can take a look at the Fountain scene which uses the exact same approach here - https://docs.chaosgroup.com/display/...cenes-Fountain
      Georgi Zhekov
      Chaos
        Hey Georgi
        i will check scene out first thanks, and try again
        thanks , much appreciated
        Harv
          ....so
          i had to delete phxshader and Particles of Liquid, and add PHXFOAM and point to my grid again.
          it now works
          thanks
          Harv
