Foam don't flow mesh when using WaveForce
  • Foam don't flow mesh when using WaveForce
    Hi
    My foam don't flow the mesh when using WaveForce. Any hint on what I may be missing in the setup ?
    Thanks Stefan
    Hmmmm, is this the wave force or displacement with the ocean texture, or both combined? The particles should get displaced at render time as long as you have a Liquid Simulator plugged into the Particle Shader, but if they don't follow the simulated waves from the wave force during simulation, this would be an unknown issue. If this is what's happening, would it be possible to send over a scene so we can reproduce it here and see what's wrong?
      Sure , its a simple scene, how can I send it to you
        You can either attach it here, share it via a file sharing service - google drive, dropbox, etc, or if it contains anything that should not be seen by anyone else, please send it over to support at chaosgroup dot com
          Its say my zip 7 file is invalid and also the max fil, I don't mind it's public
            I got share file, and dropbox , What name shall I use ?
              If it's not a problem just share it so it has open access. Otherwise you could use my username georgi.zhekov at chaosgroup dot com
              Georgi Zhekov
              Phoenix Product Manager
              Chaos
                Hey,
                Just checked over your scene and everything seems to be working correctly.
                As Svetlin mentioned in his post - it's just a matter of the viewport preview.
                You have turned on Displacement in the Rendering rollout of the simulator - this will displace the liquid mesh in the viewport but won't displace the particles.
                Though this will be like that just in the viewport - if you render the frame it should look correctly and the particles will follow the liquid surface.
                Another thing that could be useful for a scene like yours is to turn on the Air effects in the Dynamics rollout of the simulator. You can find more about it here - https://docs.chaosgroup.com/display/...ics-Parameters
                Georgi Zhekov
                Chaos
                  Thanks for the help I will try that
