Solid Object Ignore Feature
  • Solid Object Ignore Feature
    Hi all
    I've had to create an object above a jacuzzi I'm making to act as an extra bit of wall (so the fluid doesn't go over the top). This extra bit won't be rendered... it's purely for sim purposes.
    What would be useful is if you could control objects to collide with some fluids and not others... For example, I'm about to create some steam over the invisible wall.
    I haven't used smoke/fire before so all this is assumptions
    The invisible wall will have to be hidden when I sim the smoke. But, if there was an 'ignore' feature next to solid objects, that would give the user more control
    Hey,
    In this case you can use the Scene interaction rollout in the Fire/Smoke simulator. By default it is set to exclude and if you add the invisible wall object to it the sim will ignore it.
    You can find more about it here - https://docs.chaosgroup.com/display/...ke+Interaction
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Perfect... and sorry for all these questions (just posted another one too )
      A lot to learn !!
