"Clear inside" object does not delete liquid inside
  • "Clear inside" object does not delete liquid inside
    Hello again,
    I'm tweaking a scene with a non-solid with "clear inside".
    I restored my simulation at frame 110 and still at frame 120 particles were inside.
    - is that the same like using a particle tuner?
    (I'm just trying to keep the complicated scene simple, so I'm first testing the easiest method)
    Attached my screenshots, thanks.
    EDIT: I added now "Splash,Mist,Foam" Maybe that was it...
    you need closed objects for proper simulation and "clear inside" feature. Is it what you have ? (hard to understand on the screenshot)
    www.mirage-cg.com
      thanks, it was due to that I have to add mist, foam and splashes, too
