GPU rendering of cascade of water is producing these artifacts???
  • GPU rendering of cascade of water is producing these artifacts???
    I am GPU rendering a garden scene and only when I added my water cascading down a rockery is there this strange artifacts occurring in my render.
    Please can someone explain, I tried reducing the noise from 0.01 to 0.005 but that just made things worse.
    These artifacts only occur over the water of the cascade. They do not occur anywhere else in the image, so I am assuming it is a water/phoenix issue?
    Please can someone or Chaos themselves advise?
    Thank you. Click image for larger version
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    Hey,
    These look like V-Ray Denoiser artifacts that are showing when there are not enough samples in the base render.
    Do you have V-Ray denoiser enabled? How about if you disable it.
    If you have a V-Ray sun in the scene , does it help if you turn on the invisible checkbox?
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hi Georgi,
      Thank you for your quick response.
      Yes, I do have Denoiser and it is very useful
      I'll retry quickly now and report back.
      No, I don't have a V-Ray Sun, I use the wonderful HDRI's in Cosmos. Any ideas ?
      Many thanks.
      ***** Update *****
      Yes, it's the Denoiser - if I disable it, those go away.
      (but I'd like the denoiser if possible).
      However, whilst those artefacts do indeed disappear, I am left with what I believe are called fireflies (very white pixels) scattered over the water.
      Again, any ideas
      Many thanks.
      Jez
        Here is a screen grab with Denoiser switched off.
Name:	Capture_re_water_cascade_on_rockery DENOISER OFF.JPG
        Jez
          Ah in this case - check these threads:
          https://forums.chaos.com/forum/v-ray...in-reflections
          https://forums.chaos.com/forum/v-ray...-best-practice
          Hope this helps!
          Georgi Zhekov
          Chaos
            Thanks Georgi, I re-rendered with making HDRI invisible and I still get these marks (I've screen grab whilst zoomed in a lot more).
            I'll go and read up on your threads next.
            Many thanks.
Name:	Capture_re_water_cascade_on_rockery DENOISER OFF (close up).JPG
            Jez
              I must say that using the "Intel Open Image Denoise" option for Denoiser improved things a lot
              Thank you
              Jez
