Mist contribution to atmospheric effects render element on GPU
  • Mist contribution to atmospheric effects render element on GPU
    Mist isn't showing in this render element when rendering on GPU (works on CPU) - couldn't find anything in the docs about this, bug or missing feature?
    Unsure why it would be a missing feature as bubbles contribute to the atmospheric effect on GPU
    Using Phoenix 5.2 with Vray 6 for Maya Update 1
    Hey,
    The Atmospheric Render Element is not supported yet when rendering with V-Ray GPU.
    As a workaround, a Light Select render element in Light Path Expression mode can be used to obtain an equivalent of the Atmospheric Effects on V-Ray GPU with a Phoenix Simulator or Particle Shader in Fog mode present in it.
    A possible example expression would be (C[O])|(CV.*). Note though that the (C[O]) part will also capture other directly visible emissive objects (excluding the lights) in the scene alongside the directly visible fire.
    More information on V-Ray Render Elements support can be found here - https://docs.chaos.com/display/PHX4M...ements+Support
    Cheers!​
    Slavina Nikolova
    QA Specialist, V-Ray for SketchUp | V-Ray for Rhino | Phoenix
    Chaos
