Hi guys. Is there a way to do a post cache clean up? I remember Fume used to have a feature like this and it worked pretty well to bring cache files down quite a bit in size. I have some vdbs that I'd like to see if I can optimize for transferring reasons.
Post cache optimization
Hey,
This sounds like a job for the Phoenix Cache Converter tool. Using the Cache Converter, you can strip away unused grid channels from .aur, OpenVDB or Field3D files, while converting them to .aur or OpenVDB. Here you can find more info, explanations and examples - https://docs.chaos.com/display/PHX4MAX/Cache+Converter
Hope this helps!
Slavina Nikolova
Phoenix QA Specialist
Chaos
- Likes 1
Hey,
The cache converter is a command-line tool and in order to use it you will need to open it by using a command line. The easiest way is to go to the cache_converter.exe directory and start a cmd from there. The default path is: C:\Program Files\Chaos Group\Phoenix FD\3ds Max 20xx for x64\bin\cache_converter
When the cmd is started, you can drag&drop the cache_converter.exe - if you press Enter, you will see a list of arguments along with examples.
In this case, you can use the third example and modify it to remove the channels you don't need:
cache_converter.exe -srcfile ND2_PhoenixFDFire002_####.aur -dstfile outFile_####.vdb -removegridch Viscosity_phx VelocityXYZ_phx -removeprt Mist Age_phx -removeprt WetMap
Here is what this line means: Converts all cache files matching the given name, and removes the Viscosity and Velocity grid channels, and the Age channel for the Mist particle system, and the WetMap particle system. All other available channels will be written to the OpenVDB cache.
Hope this helps!Slavina Nikolova
Chaos
- Likes 1
