Spaceship re-entry heat shield effect?
  • Spaceship re-entry heat shield effect?
    Hi frens,
    i'm fiddling with a spaceship re-entry heat shield effect like in the attached pic.
    I started with the jet engine preset but i'm kinda stuck with the start or main setup to do it.
    Any tips from you guys how to approach it? thx in advance!
    I'm wondering how or what the emitter should be.
    Emitting from the Z-Axis of the shield itself and then blowing it with a wind force?
    Not really looking cool right now...
    OLIKA
    www.olika.de
    Hey,
    Indeed - the Plain force idea sounds good. Here is a sample file using the Jet engine preset as a base - I just removed the discharge modifier, adjusted the emission to be weaker and made the source emit only from the back side.
    Hope this helps!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Awesome!
      Thy so much Georgi!
      Really appreciated as i was sitting to 5am this night!
      OLIKA
      www.olika.de
        Originally posted by georgi.zhekov View Post
        Hey,
        Hope this helps!
        Do you have one for Maya that you could provide? I don't have Max.
          Sure, here is a Maya version of the scene.
          Cheers!
          Georgi Zhekov
          Chaos
            That's pretty cool Georgi. I could use this for another project coming up.
