Water waves
  • Water waves
    Hello,
    I want to create a water drop that create waves, so far create only two weak waves. If I increase the size the splash in huge, but the waves are weak.
    This is my image reference: https://images.app.goo.gl/aRNeTaew86kKsCk49
    I am using droplet splash file:
    https://docs.chaos.com/display/PHX4MAX/Template+Scenes
    Thank you in advance for any help
    Hello,
    Can you show us your settings and the results you're getting?
    Generally to get more waves you will need higher grid resolution.
    Thanks!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      The drop is 4 cm in this simulation.
Name:	Screenshot 2024-02-29 084811.png
ID:	1203493 Click image for larger version
Name:	Screenshot 2024-02-29 084831.png
ID:	1203494 Click image for larger version
Name:	Screenshot 2024-02-29 084844.png
ID:	1203495 Click image for larger version
Name:	Screenshot 2024-02-29 084901.png
        In order to get this much detail you will need more grid resolution, lower scene scale and probably more steps per frame to compensate for the lower scale.
        Also your surface tension is quite high, you can lower it to something like 0.5 or 1.
        What I would suggest is to use a displacement to add the detail in the sim - you can use a gradient ramp in radial mode and animate it over time. This way you won't have to use very high grid resolution and many steps per frame that would require quite a lot of time to simulate.
        Georgi Zhekov
        Chaos
          Thank you, doing some change in the simulation.
