Exploding foam issue.
  • Exploding foam issue.
    I am trying to simulate a car drifting through snow and having the issue of foam exploding from contact points of the tyres. Is there any way to remove/reduce this? Screenshot and settings below.
    Btw. Feel free to delete the other thread. I wanted to start this new one just in case the issue was missed. I tried raising the threshold but this still occurred (also, it removed a lot of the foam produced where the tyres cut into the snow and settled nicely... but I just need to control this exploding issue before I reduce it back down again).
    Click image for larger version  Name:	image.png Views:	0 Size:	442.0 KB ID:	1206813
    Regards
    Steve
    My Portfolio
    Hi, have you tried increasing the substeps? This helps a lot with fast moving objects... Cheers!
      I did increase to 3...I'll try higher values. Thanks.
      Regards
      Steve
      My Portfolio
        This is with 8 substeps
        Still the same issue.
        Could geo that's not solid, ie. open at the back potentially cause issues like this?
        Regards
        Steve
        My Portfolio
          Hey Steve,
          How about if you set the foam volume to 0? Usually it's the high rising speed and high bubble size that make foam explode.
          Georgi Zhekov
          Phoenix Product Manager
          Chaos
            Ah, if you have open geo - it might cause issues for sure. Your geometry needs to be closed (no overlapping faces, no open edges, no strange vertices and so on) and pass STL check modifier checks with no errors.
            Georgi Zhekov
            Chaos
              ok thanks Georgi. I'll give the open faces a go first of all and then try the volume 0 after if no joy.
              Regards
              Steve
              My Portfolio
