Hello,
Phoenix FD 1.2 is now available for download from our site. This version also includes builds compatible with V-Ray 2.0. The major addition is of course, the liquid extension - check out the images and animations in the Images section of the forum.
Phoenix FD 1.2 (November 26 2010)
New features:
(*) Extension for liquid simulations
(*) Turbulence helper
(*) Forward transfer advection
(*) Randomization
(*) Analytic scattering mode
Modified features:
(*) Added ramps and ranges in the viewport
(*) Ability to use the radius of the PF particles in the source helper
(*) Color ramp and preview range for each channel
(*) RGB preview of the UVW channel
(*) Limits for the adaptive grid
(*) Optimized the interaction with the scene
(*) Option to displace without surface projection, using directly the 3d point coordinates (volumetric displacement).
Bugs fixed:
(*) Problem with the solid sources when the temperature channel is not active
(*) Crash when a body exits from an adaptive grid
(*) The fluid can pass through a thin object
(*) When Phoenix FD is installed the CAT can't add fingers
(*) The vorticity does not affect certain areas in the simulation, especially the leading front of the flow.
(*) The GPU preview continues to update even when the window is invisible (performance bug).
(*) Crash when displacement is used in solid mode and the surface crosses the upper boundary
(*) Phoenix texture does not sample UVW and velocity channels if the node is not rendered
(*) The rendering hangs when the cell size is too small
New features:
(*) Randomization
Modified features:
Bugs fixed:
