Wind Tunnel effect
  • Wind Tunnel effect
    Need some help in setting up a simulation.
    I'm trying to archive some kind of wind tunnel effect using phoenixfd.
    Like getting a relatively thin layer of smoke blown over an object (car or something else).
    I figure I need a high discharge value but my main problem is trying to keep the smoke from expanding is there any way to regulate that? Currently I'm always ending up with big marshmallow clouds :>
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
    I'd rather approach it similar to the real world. Try a tunnel with a lot of wind and smoke beeing injected with a low discharge rather than blow the smoke from the source.
    Regards,
    Thorsten
      Thanks for the advice, Still haven't gotten exactly what I'm looking for but using a wind space warp seems like the way to go. Big thanks (totally forgot they're supported by phoenix)
      Cheers,
      Oliver
        well, the space warps are slower, you can use a big source that emits pure air in the one end of the tunnel, this must be faster
        ______________________________________________
        VRScans developer
          Could you please elaborate on that Ivaylo?
          Cheers,
          Oliver
            If you add an additional source (based of a plane e.g.) that does not emit temperature (set to 300, which is environment temperature unless you init from a tex or a script) or any other channels and has a high discharge.
            This essentially injects velocity ("air") into your grid. this is faster than Spacewarps because Max spacewarps are not multithreaded.
            Regards,
            Thorsten
              Understood, thanks for the quick answer!
              Cheers,
              Oliver
                As a side note it can be a good idea to decrease the default vorticity for windtunnel type effects to get less whirly streams of smoke
                Regards,
                Thorsten
                  Will keep that in mind thanks.
                  Additional Question: Is there a way to effect the color of the smoke?
                  Cheers,
                  Oliver
                    see the diffuse rollout
                    VRScans developer
                      now I feel stupid ^^ but thanks for the quick response.
                      Cheers,
                      Oliver
