Render underwater view of simulation?
  • Render underwater view of simulation?
    I have a camera within a volume of liquid. I'm getting strange results when using a water type material (basically the same material used in the "pool" sample file). The water surface is like a mirror which reflects the objects sitting at the bottom of the pool. No background (outside the water) can be seen through the water surface.
    Turning down the reflection doesn't help.
    you have to decrease the ior of the material
    ______________________________________________
    VRScans developer
      Decrease it to what? Isn't there an exact number?
        i suppose you are observing Total internal reflection, and it should be like this.
        VRScans developer
          Very interesting. Yes, I suppose that's what's happening.
          Thanks.
