Render Height map?
  • Render Height map?
    Hello, it's me again with the zillion questions.
    We are a game studio looking for ways to creatively use phoenix for games. One thing we need to do is render out a height map of the water created by phoenix so we can use it for distortion maps for more realistic game water. This is proving to be a bit difficult however, due to the nature of cameras and zdepth.
    Here is an image. Click image for larger version
    What I need to do is render a zdepth or height map without the darkening in the corners. It's darkening because of the distance change from the lens across the image, and I get that. Is there some way to turn this off? Or.. is there another way I should do this to get the result I want?
    I considered setting my camera way way far away and zooming but seems like a bad solution. Anyone have any ideas?
    Also tried render to texture but it doesn't like it. Thanks for any tips!
    AJ
    interesting question
    what about to put the camera above the water and to export the z channel?
    ______________________________________________
    VRScans developer
      What about planar mapping water from the side with gradient? That way you could have "height map" as a texture.
      Lasse Kilpia
      VFX Artist
      Post Control Helsinki
        Hope to make vray vector displacement mod to get a map from phx...
        I just can't seem to trust myself
        So what chance does that leave, for anyone else?
        CG Artist
          Excellent ideas fellas. The image I posted is actually a zdepth rendered from vray, but as you can see the edges get a bit dark. When you say export the zchannel... did you mean zdepth? I apologize for the misunderstanding if the zchannel is different from zdepth.
          IF I planar mapped it from the side, that may not work out because its the ripples and little wakelets that I was hoping to capture for distortion in UDK. But maybe I misunderstand... is there something I can do there?
          Thank you all for your time and patience,
          AJ
            well, use parallel projection to avoid this, when i tested the idea i did it automatically without any thoughts what exactly is stored in the frame buffer, the depth or the distance. the parallel projection makes them equal
            VRScans developer
              Interesting. I'm new to the concept, I assume that means that you just create a camera that is very far away and zoom in so that there is almost a parallel projection? Or is there a switch somewhere in the F10->Vray->Camera options?
              At work we use vray 1.5, but I also own it at home in 2.0 form if that is necessary. Thanks again for your help.
              Edit: I was thinking maybe I could just render from an ortho view and use the exposure control.
                yes, an ortho view does the trick
                VRScans developer
                  The more I learn about 3D (and it's been 12 years) the more I come to the conclusion that simplicity is the key. Thank you for your help here, this worked well.
