Can sim be calculated using multiple machines ?
  • Can sim be calculated using multiple machines ?
    I'm sure this question has been asked before. Is it possible and if not at the moment will it at some point be introduced ?
    Regards
    Steve
    My Portfolio
    distributed simulation?
    not supported yet. we have no stable technical solution for the moment, the buffered conservation method was introduced planning to use it for network simulation (it is possible with it), but it can't simulate liquids and apparently the liquids became the main feature.
    ______________________________________________
    VRScans developer
      So, the buffered conservation method sounds interesting. I am simulating fire/smoke at the moment. How would I set this up ?
      Regards
      Steve
      My Portfolio
        you didn't understand me correctly, the buffered conservation is technically possible to be used for distributed simulation, but it is not implemented.
        VRScans developer
          Oh I see. I for one would like to see it implemented at some stage
          Regards
          Steve
          My Portfolio
