Phoenix Toolbar
  • Phoenix Toolbar
    Just spotted the tool-bar... will be a handy addition! I'm assuming its not working yet though :P
    Adam Trowers
    Well, the idea is to start your simulator without having to select it and go to Modify. If you have many simulators, a list has to pop up so you can select which sim to run. Pause and stop should affect a running simulation. Still no greying out of buttons, etc, but the above should be working in today's nightly...
      Ah cool.. well I'm getting no response from it. Using a scene which was originally made with a build from 2 days ago. Also I use the 2015 vray 2.4 build with Max 2016 if that has anything to do with it
      Adam Trowers
        Aw, snap. I'll bet on max 2016... Will check it in a sec
          Oh wait - you're doing *that* thing? Most people can't even load Phoenix this way..
            Do the hints on your buttons say gibberish?
              Yep >>>> !@!@! <<<< something along them lines What is 'that' thing, installing 2015 to run with 2016?
              Adam Trowers
                Yup, it's a bit naughty to install 2015 for 2016.. do you do the same with V-Ray too? Anyway, I reproduced the issue here using a canonical install, so no prob
                  Well I never used the 2016 version as there isn't one listed for vray 2.4 :P Will the vray 3 version work? Yep I do the same with vray aswell as there isn't a 2016 vray 2 version for that either, last time I checked anyway.
                  I've tried to convince the boss to upgrade, not working so far
                  Adam Trowers
                    Yup, there's no V-Ray 2.4 version of Phoenix for max 2016 because there's no V-Ray 2.4/2.5 for max 2016. The 3 version won't work with V-Ray 2.4, so you really have to do the install hack.
                    Got the bug too - usually the first time you run max after you install Phoenix everything will be fine, but the second time and so on max will decide to load Phoenix after its toolbar, so the toolbar will remain orphaned and useless. The fix will miss out tomorrow's nightly unfortunately, but will be there for Friday...
