Hi! Is it possible that the SHIP.MAX example scene do not display the foam and splashes? I loaded and simulated it with a lower grid resolution, and I do not see any foam or splash at all when rendering it.
Ivaylo Katev, would it be possible to get the scene you used for this render with the new Flip solver? I would like to see how you did it, it will save me lots of time guessing.
definetly this example scene does not work correctly with the latest beta. I solved a few frames at full resolution and the foam and splashed do not render.
well... I hope you can make that scene available, the results I'm getting with the controls that are available today with the fl;ip solver do not look at all like water or ocean or waves from a ship but more like a thick liquid and all seems out of scale, and I can clearly see the edge of the simulation box with the ocean even though both have the same level. It looks nothing like your render on Vimeo.
Thanks! I need to see why my attempt looks like chocolate and not like water and why I see the borders of the simulation even though ocean and fill up are at the same level.
