procedure for image-based color smoke?
  • procedure for image-based color smoke?
    Hi guys,
    Recently we use FumeFX to create some nice nebula. It is an image-based volumetric smoke. We use photos of the nebula from NASA and sim a few frames. And use static smoke as a nebula. Here is similar technique we used:
    https://vimeo.com/65370346
    May I ask what if I want to create the same effect with PhoenixFD, what are the steps?
    Chen
    Hey,
    This should be very easy - enable RGB in the Output panel, enable RGB on the PHXSource and pass the map there
    Cheers!
      tks Svetlin, will post some images
