Maya Noise as Discharge Map
  • Maya Noise as Discharge Map
    Hello
    I realised that using Maya Noise (Billow, Perlin,...) in the Discharge Map slot of the PhoenixFDSrc doesn't seem to work
    File Textures seem to do the trick
    How would you get a animated noise pattern onto a source object.
    Using a image sequence would work I suppose, but is kind of lame for its not very interactive
    Thnx
    Martin
    Hello,
    For the Noise map to work you need to Turn on the Alpha Is Luminance option in the Color Balance Tab.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      works like a charm
      thanks a lot
